Does the make of a carb change the jetting, for example Ive got a XS771 and my buddy has a JetWorks 771, We each have our respective builders carbs (XS and BlackJack) could we just swap dual carb set-ups? Im assuming the answer would be "no" but both the set-ups have the same set-up only difference is the builder.
If I'm right and the answer is no its not a straight swap, what would change pop-off or jetting? I know the the XS carbs have a dual check installed for a bigger pilot jet
Thoughts?
Thoughts?
