That is difficult to predict. The engine should be fourcycling a little around 1/4 throttle and the top screw should be set a few rpm rich of peak, or for best acceleration which is usually the same. The common range is pilot 120-130, popoff around 20psi, and a 150-170 main depending where the top screw ends up.
