- minnesnowda
So I have a 760 62t/62t in my sj, fp blaster mod pipe, milled head- 175psi, rec cylinder porting, ported case, carbon tech reeds, stock 38's with prok fa's and a primer kit. compression is within 1psi each cylinder, hot and cold. rebuilt carbs to try and help chase down this issue so all parts are new also. 99% of the time it starts without primer or throttle. idle is consistant and smooth and I can easily change it with the idle screw. seems to have great response and overall runs good until I hold it at a constant rpm for more than about 15 sec? it physically runs ok but when I go wot I get what feels like to me a slight lean hesitation? I get a sporadic slight bog off idle also? I tried 3 diff springs on my n&s, going up and down on my mains and lows and it changed it some but my original jetting seemed the best (135m, 75p, 2.0ns, ls 1, hs 1.25). this is where it gets weird? as I jetted up the pto cylinders plug got way dark, the mag plug didn't seem to change much if at all? tried staggering the screws, and eventually the jets but I still couldn't get the plug to what I would call safe? any ideas whats going on? could I have some bad reeds? crank seel leaking? any ideas? let me know what you think. -Jesse
