ANT
Just ride
- Sea Isle City, NJ
It runs good for about 20 minutes then starts breaking up. There was water in my e-box but i got it out and cleaned everything up with electrical contact cleaner but still nothing. Tried a Jet ski solutions coil and still the same symptoms. Changed out my MSD and tried my stock CDI and still the same problem, running bad after 10-20 minutes of riding. Not positive whether the JSS coil is good because who I got it from said he wasn't positive if it was good or not, but it ran fine for a little then started messing up. The weird part is, the last time i was out with it, it was running bad but not real bad ( it gets real short bursts of clean, the way it should be, power), I stopped on the beach for 5-10 minutes then when i pulled off the beach to go load it up it was barely running on both cylinders. It's a real weird problem, maybe someone here has had similar trouble before?
