Cable Maintenance Question
I am pulling the SJ out of storage this week :woot: . I picked up a cable luber, but searching over at PWCToday I found people using WD40, silicone spray etc. Should I use something heavier, what do you use to lube your cables?
The other Alex
(Jetdude)
Lake St. Clair--
Nate, I just give a shot of silicon lubricant on everything. I used to use WD 40, no problems with it. Then I picked up this silicone lubricant spray and have been using this with no problems as well.
