Blaster BROKEN DRIVE COUPLER HELP
iowa
Should I install a new OE coupler or convert to the Kawi drive coupler. seems like that is the only style available if I go aftermarket. Who sells a good drive coupler for 701 B1. Do I need the flywheel lock to remove the old coupler?
Go with ada or cold fusion coupler, they don't shatter like stock. Piece of rope in the cylinder is very effective for getting couplers off, apply heat too, should be easier to remove.
