FX-1 Broke motor mount plate off. What to glue it back with?
Edmond ok
So I noticed it felt like I had a broken motor mount. After lifting up on the motor I found that the fiberglass piece popped off the hull. What should I glue it back down with?
Can you send me a link to the best stuff?
blasterdude
Waiting for the ice to thaw!!!!
The Region
SEM panel adhesive should do the trick. Just clean both pieces well and ruff them up a little and then glue it back down.
BrightE's
Paul
Seattle, WA
Agreed with SEM panel epoxy, though really any thickened epoxy would do just fine. My only reco is to rough the surfaces heavily, not a little. Use 36 or below grit, don't forget to clean the surfaces with acetone first so you're not sanding oils and greases further into the composites.
Sent from my LG-F350K using Tapatalk
