bought a beach cart today...
demolition_x
Not After Fame & Fortune
its too wide so i have to make it narrower but for 50 bucks i think i got a good deal.
beach here i come
Not bad at all. You have something to work off of and those tires will work in the soft sand and anything else so I say you got a hades of a deal. Some people call it hell but, I call it hades. If you were in the new freeride capital of FL I would see if you wanted to sell it.:biggrin:
demolition_x
The Penguin said:
you got a smokin deal!
shoot a PM over to Rickster. I sold an identical cart to him and he narrowed it for an SJ - I'm sure he can give some tips
the U is going to be the only problem. there are pipes that are in the middle to keep the distance from the bunks. they only site in a pocket so i would have to cut them. then theres a threaded rod in the middle which holds the sides together.
douglee25
m3booooy
South Jersey
For the U portion, cut it down the middle and then cut equal distance off either side that you have left. The join them back together by sistering a piece of metal on each side (also known as a lap joint). You can drill and bolt vs. welding if you don't have a welder.
Doug
Rickster
Matakana Menace
Doug
That is what I did. Cut a 4" peice from the middle of the U section, and got it welded back together. They I just cut 4" off the three tubes, and it works wonderful.
These are awesome carts, so if you ever want to get rid of it, PM me...:biggthumpup:
demolition_x
well my father decided that he wants to use it for fishin on the beach now. so we are rigging up 2 bunks in the middle of it. this way he can still stick his coller in the middle when the bunks are out.
hard to explain i'll have pics when its done
