This winter i'm putting together a big bore motor, and have some questions as this is my first go at this. The top end is a ATP head, with 35cc domes (also have 40cc), 61x cylinders, resleeved and ported, bored to 84.5mm (762cc) with wiseco pistons. I want to stick to a 44mm mikuni, but its the bottom end that has me up in the air (pardon the pun). Regardless i need to bore the cases, to fit the sleeves. I currently have a 61x bottom end. I was considering trading some parts for a 62T bottom end with dual 46mm intake. both need reeds regardless, and i want to settle on something before i order a gasket kit.
the motor is going in a basically stock mint square nose hull, till i can afford an AM hull. I will have a solas 12 vane, and hooker 11/17 prop behind the motor. If i went 62t, i would have to get the new bar to run dual 44's off single machines, if i went 61x my current carb is highly jetted enough to handle the requirements of the big bore (i think) 160M 120P. ski is mainly to learn on and grow with, and i have no problem going to 62t next year.
So, what do you think? if i went 62t, it comes with a 61x top end that i would bolt to my 61x bottom end and drop into my sit down that has a 650 in it now.
Thanks for any advice!
