Foximus
CFL Cheapass.
- Oviedo, Fl
Searched around a bit and I know that you need to bore the B pipe to 47-49mm, however I cant find specifics...
I measured the manifold, and the opening is at 46mm, but just below that is a taper down to 44mm. I figured it is obvious this needs to be bored out to 47 or greater.
But then I checked the headpipe. That measured in at 42mm. WTF?
Obviously I could bring out the headpipe to match, but with that aggressive curve through the pipe I could only get so far and then it would most likely taper back down again before opening up.
So someone enlighten my situation.
