Well crap - that didn't work out so well. I'd forgotten that the backing plate for the pole bracket covers the bottom of the hooks, so I went to take the plate off - it's stuck like sh*t to a blanket! Can't get the four outer bolts to pull out (although the nuts came off easily enough). It's still 97* out there after a 100+ day, so it's way too hot to be wrenching. That means it's be getting some 6mm bolts and I'll be machining the heads so that I can use the stock nuts....
