Super Jet blowsion phat clamp question
Just bought an xmetal steering system and want to experiment with a couple different bars. Im just wondering if the blowsion phat clamp will work with it and if you can use any 1 1/8 bars?
I have a blowsion phat clamp bar sys. on my superjet running with an x-metal pole. With straight bars it fits but it is tight. If you are using riser bars you will need to trim the pole pad to allow the bars to rotate correctly
