Blowsion chinpad
Kuwait
Hi, I have a completely stock superjet that i want to put a blowsion chinpad on. I want to keep the stock steering and the black cover that hides the stock turnplate. Can the blowsion chinpad mount on the stock superjet pole and fit with the stock steering cover?
Thank you
Roseand
The Weaponizer
Wisconsin
What year ski?
Don't waste your money on a chinpad. Spend the money on a new steering system first.
Vumad
Super Hero, with a cape!
St. Pete, FL
It's a post 08 ski. I prefer to keep this ski stock except the color.
Will it work?
I've never owned a blowsion carbon chinpad so I am not going to say whether a carbon replacement works or not. However, You stated stock and just changing colors, so I'm not sure if you are asking about the replacement carbon chinpad or just the cover. It seems strange to buy a $260 chinpad for an all stock ski over a heavy duty spring and a new cover. If you are just getting the cover, see the highlighted area below. Blowsion says the cover will fit on the stock pad but requires the stock pad to be modified. Jet trim has a nice option, blacktip has them too. Hydroturf makes them but I don't see them online.
Cover replacements state they will fit with modification.
https://www.blowsion.com/chin-pad-cover-glove-fit-96-super-jet-and-fx1
"Blowsion custom stitched glove-fit chin pad covers for 1996+ Yamaha Superjets, FX1 and Polaris Octane. Specifically designed to fit our Blowsion Carbon Chin Pads but will also fit OEM Yamaha chin pad backing with slight modification to OEM plastic backing and foam padding."
This is a full carbon chinpad.
https://www.blowsion.com/chin-pad-carbon-96sj-octane-kawi-conversion-1
There are other options too. This is jet trim.
http://www.jettrim.com/watercraft/yamahastandup.html
Blacktip lists them under custom seat covers. It's strange it only lists to 2009, you should verify with them before purchasing.
http://www.shopsbt.com/jet-skis/yamaha-jet-ski-seat-covers.html
Kuwait
When I said cover I meant the black plastic piece that covers the stock handlebars mounting bracket. and turnplate. It is removed when people change the bars or turnplate on their superjets. I like how the cover hides the turnplate and steering mount. I was just wondering if I could keep that piece if I mount a blowsion chinpad. I was also referring to the blowsion Carbon chinpad when I asked the question. It is shaped a bit different than the stock chinpad so I was curious about the compatibility.
Thank you
