blaster impeller in 701 SN SJ
dfw
The blaster prop is about right if the stock rev limit is used. It will be too much load for best low speed response though. Those old props are great once the boat is moving but lack the low speed thrust of newer thin hub and swirl props for equal peak RPM.
If you liked it enough to spend more money on it, I assume you are satisfied with it.
Who is Hill. How much have you spent for original impeller and work?
