if got the cash get the bilge pump kit from blowsion, and also the rotary switch. If not you can get an attwood 500gph pump and hose from Walmart for pretty cheap. Get some wire and a cheap switch, the switch may go bad after a while for for $2 its no biggie. I mount my pump either right next to the coupler if theres room or on either side of the hull near the back by the bulkhead. If you run two, run one front and back of the ski. Use some marine epoxy to glue it down or some places and brackets you can bolt to things. Exit hose near were the hood meets down to the hull by the bulkhead, it needs to be above the waterline and in the hull you can put a loop in the hose or make sure it sticks up a bit so water doesnt want to drain right in. hope that helps.
