Bilge Pump Install
Can somebody explain to me how to wire a rule 500 bilge pump, with a switch with the red, white, and blue wires. I also have an in-line fuse holder.
Please be specific, thank you
Think I got it, for anyone with the same question:
Black bilge pump wire to negative battery terminal
Brown bilge pump wire to white switch wire
Red switch wire to fuse, to positive battery terminal
Blue switch wire get capped off
You can also wire it so the switch is grounded instead of sending power. Positive is fused directly to the positive pump then the switch breaks the ground.
