Mark44 said:Is the hose an 1 1/8"? and the fitting a 3/4" Take a pic if you can and post.
Mark44
Mark44 said:¾” to 1" fitting in McMaster Carr #53415K136. I think ¾” to 1 1/8” you will have to make one up or the easiest way would be getting a bilge with 3/4" outlet from Wal-Mart.
Mark44
2002zxi said:Can I just wrap electrical tape around the bilge fitting and then zip tie the hose to it?
2002zxi said:I bought 2 500gph pumps from walmart yesterday, the atwood ones. I looked in the bottom of the ski and found the base to what I thought was the atwood model already epoxied in there. It turns out it was for the Rule 500gph version. I'm getting a Rule 500gph to sit back in that base and the rule 1000gph one for the center between the engine and fuel tank. There are already matching 45* fittings in the front of the tray that shoot neat arcs of bilge water. I bet it will shoot really far with the 1000gph version of the pump
Mark44 said:
I guess you could do that but......Damn ugly......There has to be a better way. j/k The Rule fittings are 3/4" are they not?
Mark44 said:I would say take back the 1000 and get another 500. If I remember correctly you have a scupper valve so you really don't even need 2 pumps. I hardly ever use my pump because of the scupper.
Mark44
2002zxi said:But... but... when I bough it it had 2 bilge outlets already!
2002zxi said:I'm still going to get the 1000gph one for my other ski. It has no scupper and only 1 500gph bilge pump.
Doesnt it look cooler shoooting out of the 45* bilge outlet at 1000gph though?SJKny said:IMO the 1000 is still overkill.... normal riding only calls for one 500, if that.
