You can grab the shaft in a vise beyond the seal and bearing surface closer to the coupling. That way you will not scar up the seal surface, then heat it up and it will come right off with a large pair of channelok pliers or a pipe wrench, I have a chain wrench I like to use if you have one, use that.
