Freakrider
X247
- Tampa Bay area
Yamaha 760 currently 85mm (max bore) rear cylinder slightly scored from air leak/lean condition, I have the entire motor apart down to bare cases..machine shop guy looked at it and says just hone it "anything left on cylinders won't amount to a hill of beans". Three options : #1) I was thinking of going with 85mm wiseco pistons or pro-x... hone both and put it together.#2) I would try to buy some used cylinders at 84mm and bore them.#3) buy some new sleeves and I have a friend who can put them in.(but hear that oem sleeves are the hardest/long lasting) I plan to use all new oem gaskets/crank seals. Thanks for your opinions.
