Super Jet Best steering syst. 2013 superjet
New superjet and doesnt turn that well, any help? would the blowsion Kommand steering system be a good upgrade? i plan on keeping the stock pole. or are there any better steering system.
I have 0d bars so i dont wanna re upgrade to phat bars or anything
i also plan to drill a hole closer to the nozel and grind more turn out of it
Wisconsin
The cold fusion plate that uses the stock bushings certainly improves how fast it turns, great mod, plus its only like $70. I have a friend with the Blowsion bearing steering system. Quite a bit more expensive, but it will last forever if you take care of it, probably smoother and it will never have much slop. With the cold fusion plate, you have to re-tighten the bolts on the bushings once and awhile but who cares. Personally, I'm happy I went the cheaper route because if the bushings wear out, they are a lot cheaper than any bearings, that's for sure.
Jetmaniac sells the cold-fusion stuff if you are interested in that.
I noticed in a different thread that you just bought a 2013 superjet, that is sweet! Get a scoop, tubbies and a pipe for it and you'll have even more fun.
I just did the steering mod so that helped a ton! much better now. ill look into the cold fusion one! Also you have any idea whats a good scoop grate? theres so many, top loader, maxiloader, pump stuffer, r&d, worx, jet dynamics. just dont know whats good or not
The umi is king but if you want to look kool with riser bars then ada turnplate with umi bearing system.
Sent from my DROID RAZR HD using Tapatalk 2
Wisconsin
I can't supply any information on '08 plus scoops unfortunately. I would do a search about that. I will tell you that after trying a few different scoops on older superjets, I have had the most benefit from a jetdynamics scoop by far. I hear worx is the way to go for '08 plus though, wish I was a bigger help.
