FX-1 best mods to start with
so i am getting an fx1 satt from a friend and it has a r&d head and and a big carb
i gess i need a pipe which pipe do u think in the 400ish range still open to more $ if need
do i need to do double carbs if so which ones
and is there any other thing i should do other then porting and pollishing
thanks in advance
Surf, waves, flatwater?
Mine has:
Handling-
Jet dynamics Grate and Ride plate
Ocean Pro nozzle
Skat Trak Swirl 20/26
Engine-
Protec/Blowsion 180psi head
Factory B Pipe
Lightweight flywheel
MSD cdi
Stock carb, flame arrestor
You first mod should be a front hood latch. Then the rest depends on what you use it for.
main will be flatwatter and waves from boats but will be used some in surf
the front hood latch what do u meen by that ? and should i get hood straps
utah
I'd put some hood straps on it for sure. I had the hood pop off and sunk mine with in 24hrs of owning it. I put ratchet hood straps on and have rode it way hard since and the hood stays put.
550headache
tobacco grower
tobacco valley
tubbies! made a huge difference on the un-predictable carving(at least for me). I used blowsion destroyers but everyone recommends tom 21 tubbies. just got a set from him for my superjet and they are very nice!
