bendix: washer, spring, grease, goo, corrosion, hamsters on a wheel, etc order?
A large thin flat washer goes between the drive and the case. A small flat washer, then a spring then another small flat washer is in the front cover ( with grease)
Foximus
CFL Cheapass.
Oviedo, Fl
i used to dunk in ATF. But no longer. If I have a new bendix I will install it dry. ATF is very thin, and slings everywhere just making the entire timing casing to be a mess.
If your going to dunk it in anything at least get some TriTeflon fluid. At least that will penetrate and stay in the surface of the metal.
