Super Jet Bendix lube and water in flywheel cover...
Little update: Because I am paranoid, I pulled the flywheel cover on my motor last night. I didn't want to install my motor in my Superfreak without being 100% sure about it.
Turns out it was a waste of a gasket. Completely dry and nicely lubed.
This is after approximately 250 gallons of gas through the motor and multiple sinkings/near sinkings.
baldwin ny
make sure you starter is still water tight. i had one drive me crazy. turned out to be the starter body was leaking water into the stator cover.
