Are the passages through the jacket at the top of the pipe always blocked off like that? Should I clean it up to match the gasket and open the top passages ?you could take a dremel and clean that up some.
Pretty sure the top doesn't have a water jacket. It looks like if you cut into the top you would just come out the other side.
