beachedflunkey
wavejunkies
- Virginia Beach
Engine:
701 w/Magoo freestyle port
ADA girdled head w/35cc domes
Dual oem 44's on r&d manifold (might need tuning because they're not much better than my 38's)
Fiberglass reeds, boyesan stuffer, reed spacer, stock f/a's
Magoo lightened flywheel
Fp mod bpipe
TDR baffled waterbox
Kenney keepers
3 monkey grip motor mounts and one unknown :afro:
Electronics:
MSD enhancer
2x attwood bilge pumps
Handling:
-2 xmw pole w/bracket (need shorter)
CG Racing chinpad
-2.5 xmw steering and straight bars
xmw throttle
Lizardskinz grips
CATS based off Raider trim
Quick steer modded nozzle
dcut stock ride plate w/3" radius
Tubbie 1's installed with glass/epoxy
Front and rear dakine foot straps
13/15 cutback 3mm solas concord
wetwolf freestyle cone
worx 201 intake grate
Hull:
Front half reinforced w/2 layers 17oz 45deg biax
3 layers biax under pole mount
1 layer biax throughout entire right gunwale (3/4 br side)
WCF footholds w/rear entry reshaped and padded
WCF hood
WCF CF nose piece/cowling
Tray reinforced w/ 1 layer 12oz glass mat
Mostly refoamed w/3lb uscomposites foam
Blowsion one-way valve (would prefer custom jobber but didn't know better at the time)
Blowsion hood straps
Extra ubolt for ratchet strap when/if hood latch breaks
Homemade limiting rope
Nason poly-urethane primer
Imron poly-urethane paint
Hydroturf w/25mm and a little 5mm padding
N2Graphics vinyl
Fp mod bpipe
Kenney keepers
Electronics:
MSD enhancer
Handling:
CG Racing chinpad
xmw throttle
Lizardskinz grips
Hull:
WCF hood
N2Graphics vinyl
