Super Jet Battery connectors
I remember someone was selling machined brass pieces to change the way cables attach to batteries. They would get bolted to battery posts permanently and then cables could be attached at a rotated 90 degree angle. Does anyone know what I'm talking about and where I can get those?
Also, did anyone ever try to make waterproof quick disconnect plugs for battery cables? Male and female ends would clip or screw in together and it would reduce time it takes to remove a battery and there won't ever be a problem with lost bolts.
Sospikey
Trying to get upside down
Sweden
Not water-proof, but these are quick to disconnect:
I think these are available through Hot Products or your fork lift dealer
Delaware
Do those come with that cable or did you choose it?
Car stereo power cable? If so you might find is doesn't last long in marine atmosphere. Thick braid tinned copper is way better.
Sospikey
Sweden
I choose it. I only ride fresh water and I think silver plated or tinned would be the ticket for salt water use. I do like the way you can bend the car stereo stuff though. I have been running these cables for 5 years now, on both my skis.
