Surfriding Barrel roll question
I'm just starting to roll in the surf have been landing on my head alot not getting the full rotation but also what stance should I be in for this I've been trying it in surf stance any other tips to get the rotation
I just started doing them as well. I use surf stance and drop the pole down reallll low, cut opposite way an use your head to spot the water. Your body follows your head.
Tuscaloosa, AL
as you come up to the wave, crank the bars the direction of your rotation. lean over bars, drop your shoulder/elbow on that side. Best Advice I ever got for flat water rolls was to "try and look under the bond line". If you do this, the ski will follow.
