Super Jet b2 lowered pole bracket install help
just got my b2 in from fast elements, trying to install now its not as easy as i expected. No directions or guidance. My first question is the bracket is supposed to move the pole postion forward so im assuming the angle part goes toward the front of the ski making putting the pole further up? my second question is what are the two longer bolts with black blocks for? And last but not least how does the handle pole spring mount inside the new bracket? cant seem to find a hole in the bottom of the bracket that would line up.. if anyone can sshoot me some pics or have any guidence that would be sick thanks
i think the bolts with the blocks r for the handle pole stops, thats the way it is on my rrp bracket, and yes i would think the angle part would got towards the front might have to trim your nose piece some, adn u might have to drill a hole for the spring, it might b set up for no spring running a tight pole, or u might have to buy a spring perch for it, like for the rrp brackets, hope this is some help i dnt have my rrp bracket with me to take pics of how its setup
