Blaster B1 FPP MOD Pipe/ Top Bracket not lining up
Mike W
Infidel
North Florida
I have been dealing with these for years but never ran into this issue. The top bracket on the MOD chamber and the 90* cylinder bracket will not line up. The bracket on the chamber does not appear to be bent but it is possible. I don't have another one to compare it to.
Any ideas???
theiba
Can't get a ski stuck...
Southern NJ
^ Yep. I just finally got around to installing my mod pipe and I screwed with it for an hour before I finally managed to wiggle it tight up against the head pipe. Even then, the brackets didn't line up perfectly, but close enough. It looks like if your chamber was pushed another inch into the headpipe it would line up perfect. It's hard to tell how it's sitting on the front case bracket, but it looks like it should come back a little.
I tried windex like everyone says here, but by the time I managed to spray it on the coupler and slide the pipe into position, that :):):):) was dry and sticky. That's what was causing me not to be able to butt it up against the headpipe.
