Polish jet pilot
4aces4aces4aces4aces4aces
- Warsaw, Poland
I have a pretty stock (engine wise) 62T motor with R&D angled spacer, choke butterflies removed.
I wanted to get as much bottom end power from my setup. I got a real nice B-pipe with bored exhaust manifold and polished windows. I run cooling in such a way: 1 cooling line from pump, this line gets divided into 2 lines that go into the exh manifold. From the OEM head I run 1 pisser overboard. The other line goes to the bottom of the headpipe. The rest is pretty standard with a T piece that directs rest of the water outside and waterbox.
I have been testing the bottom end power adjustments. Before I started with pretty standrd adjustments gotten from memebers and builders from here. Start 1 turn out on the top screw. I have been testing this for some time. The power was there, but it felt significantly stronger in the mid and crazy fast on top. I gradually increased the number of turns on the top screw and currently have two turns out. The ski is completely different. Still fast on top, but the bottom is explosive (in terms of a stock 701).
Turning 1 screw made all the difference and it felt like I would buy a performance part worth 400-500 usd.
My advice to all the guys getting into this hobby/sport: get a b-pipe before any other "real" performance part and play with it. It will allow you to really start practicing some tricks. The power really allows you to do so much more...
Have fun!
Andrew
Have fun!
Andrew
