SOLD ATP Flame TS2 total loss
McDog
Other Administrator
Staff member
South Florida
This setup is for 61x or 62T Yamaha watercraft 2 stroke engine cases. It includes the billet ebox so this works great for saltwater or freshwater applications. 100% gone through on the wiring by me and guaranteed to be plug and play. All you have to do is remove your ignition and install this with the mark on the pickup plate lined up with the arrow for aligning your stator on your cases if you have a stock stroke engine. I will help you set it up regardless of what you run it on. Comes with 2 curves: one for freestyle and one for surf but it is fully programmable with your laptop and software and programming lead are included.
This system is comparable to MSD and throws 2 sparks for every revolution to ensure complete combustion. Includes kawi coils as recommended by ATP for max spark power.
The only negative is some wear on the flywheel teeth in a couple places that I included pictures of but it never missed a beat on startup. Flywheel also has some cosmetic rash from previous bendix failure.
Only selling because I cannot use this ebox with the mounting setup on my hull and this was an extra system. I still run an ATP total loss. They are bulletproof unless your son hooks your battery up backwards.
$800 shipped obo
McDog
Other Administrator
Staff member
South Florida
20201127_164636.jpg20201127_164353.jpg20201127_164343.jpg20201127_164240.jpg20201127_163940.jpg20201127_163924.jpg20201127_163846.jpg
