- Ocala, FL
I have a 140mm kawi (x2?) pump with the trim nozzle and it was missing a few pieces when i bought it. It uses some bolts/studs to mount the trim and steering nozzles in place and i have 2 out of the 4 i need but i have no clue what they are called or where i could purchase them. Also i need the 4 bolts that mount the reduction nozzle onto the pump, does anyone know the proper dimensions needed? I also need the mounting hardware for the steering cable. I will be using the pump on an fx1 so Im not sure what type of setup is required but right now its just an empty nut on the nozzle and the standard cable on the fx1, any ideas?
Lastly, what type of grease should i use for the pump? It has a red grease inside the cone but its mostly gone. I threaded the prop on today and it fit fine and the bearings seem good so i just need to grease it and it should be ready. Do i fill the cone with as much grease as i can?
