Boris
The Good Old Days
- The surf-less coast
When installing an X-metal trim on my trusty old SN I went ahead and welded a piece of aluminum to act as a stop on the bottom of my nozzle. Didn't want the cable to be under constant strain when the trim wasn't being used.
Anyway, I welded it on where the trim ring wouldn't sit at 0* but more like 2* or 3* up (bout what a pump wedge would be) thinking that I could always file it down to the final setting.
Is any of this making any sense ?
So, I threw the ski into the lake and took it for a spin and instantly noticed that it felt a lot more playful. As if the hull got shorter and lighter and wanted to change directions much quicker. Riding more nose high with less hull in the water would explain it all but here is where things get weird. The sucker turns so much better now.
I was dragging elbows at will without a hint of sliding out. That just goes against all norms and it should be quite the opposite but the sucker actually rails. WTF ?
Pulling a hand full of trim mid corner when the ski is laid over makes things very interesting.
Thrust vectoring is a blast.
Any input ?
Any input ?
