Ant Burgess BACKFLIPPIN in the UK!!!!!!
Post from PWCTODAY: Full Throttle.....
Heres a video Ant sent me from last month riding on the full throttle SJ
Cant wait to see what he is going to do on the new 24-7 carbon hull i am bringing him next month the hull in the video is 90lbs just the hull and the carbon sj is 68lbs with hood!!! Killer job Ant keep up the good work. He also wanted to thank Pat from X metal for all the parts.
YouTube - Ant Burgess Back flip
:woot: :Banane01: :cheer: :biggthumpup: :purr:
aof13
Sfl free since 3/28
http://www.youtube.com/watch?v=M5sCpVvbtgI
68 lbs carbon? It's probably paper thin, unless its pre-peg.
G
Goose
Guest
Im pretty shure that boat was got cracked at the rager.and I did hear him say it couldnt be broke
Details from pwctoday: Thanx 2 Full Throttle!
the motor is a 991cc 10mm lamey PV stroker running on 185psi comp
PUMP GAS TL and full spectrum carbs
The pump is something larger then a 144mm that skat trak made us
that was the hardest thing to get the boat to put the power to the water at WF this year the motor was only at 140psi comp with out the TL because we still wherent able to get it to hook up. We are working on a larger motor for Ant that will be a 1063cc 12mm stroker. Cant wait to give it to him.
Exile" Dammmmmmmm!"
Never heard of a 12mm stroker. (On Yami 701 Platform)
Cases are paper thin at 10mm, and I think I remember seeing that the Lamey cylinder ports don't flow enough volume past 76mm stroke.
IKSTEJ
BOGIE
Region 7
If thats what Marks putting together now..........
I can't wait to see what he's got when he gets some ...... experience :cool2:
