douglee25
m3booooy
- South Jersey
OK, here are the details....
Symptom: I rode today for about 4 hours. Everything was fine until last 10 mins I noticed that pisser #2 (rear cylinder) was not flowing much at all.
Cooling setup: Pump to bottom of exhaust manifold (single cooling), front nipple on head to pisser #1, rear nipple on head to top of head pipe (riva red pipe), bottom of head pipe to T where one line goes to pisser #2 and the other line goes to a jetworks valve on the stinger.
Tests:
1. Compression is 180 rear cylinder, 170 front cylinder.
2. Running the ski on the hose does exactly the same thing as it does in the water.
3. Back flushed every hose. Flow is great out of all hoses.
4. When running on the hose, pulled line from front of head going to pisser #1. Flow is outstanding. When the line is hooked back up, pisser also shows outstanding flow.
5. When running on the hose, pulled line from back of head going to top of head pipe. Flow is not even close to that of the front of the head. Hooking the line back up exhibits the low flow seen on pisser #2.
6. Pulled nipple off of rear head. Nipple is clear.
7. Hooked hose up to rear of cylinder and flushed to front. Good flow out the front nipple.
8. Hooked hose up to front of cylinder and flushed to back. Good flow out the back nipple.
9. Ran ski on hose and pulled both lines from head off simultaneously. Front has great flow but rear is still low.
10. Front piston (170 psi) has a good carbon pattern. Rear piston (180 psi) has little to no carbon on piston crown.
At this point I'm stumped. I thought it could be a blown O-ring on the head (protec). I also brought piston to TDC on each cylinder and flowed water into the head. No water was seen in either hole. I even bumped the starter and nothing came out.
It's obvious that there is not an obstruction in the raw water line from the pump if the front portion of the head has great flow. It can't be a line after the head pipe because the low flow seems to be coming from the back of the head. Could there be some sort of obstruction in the cooling passages inside the jug? How about at the entrance to the jug where the exhaust manifold bolts up? Head O-ring?
I'm stumped?
Any suggestions?
Doug
Tests:
I'm stumped?
Any suggestions?
Doug
