Prem1x
Tinkering obsessed
- Austin, TX
Yamaha gives a spec of 0.012" for impeller shaft runout, but I don't see anywhere a spec for how well the shaft should be centered within the hull where the mid-shaft bearing housing mounts to the inner hull. Anybody know how close to center this needs to be?
Background: the bottom of my ski was re-gelcoated and I think the extra thickness of the gelcoat where the jetpump mounts to the hull has thrown this off a little so I am planning on sanding it down some.
