- South Florida
This xs771 motor with 44 blackjacks has been a nightmare so far. No ones fault but my own I might add.
So far it has seemed lean and not tuned correctly. Then it sunk, hydrolocked and busted a set of reeds. Then it was discovered during continued difficult tuning that one of the fuel lines was slit on the inside where it connected to the intake on the carbs. It was leaking some and definitely pulling air in. New fuel line seemed to fix the problem and it was spot on.
Today I put my wife on it for the first time and it was perfect for about 20 minutes. Then I see her by the dock and get the "something is wrong" look. Suddenly the ski seems to have a huge airleak. Lean as hell feeling and will go if you dump some fuel in with the primer. It is also making a weird vibrating or clicking sound around the carbs that I cannot find. It also revs to the moon when you jump and get air in the pump.
I pull the motor and it pressure tests fine. I pull the intake and the reeds look perfect. Now I'm tired and stumped. Maybe something inside the carbs?
