after shredding coupler, ski won't run under load
After a big hit, I broke my rear motor mounts. When the motor dropped back down it shredded the coupler (on the engine side). I replaced the couplers and put the motor back in. The motor runs fine on land, but the moment it hits water, the motor shuts down. As soon as the motor is under load it bogs down and cuts off. Before the hit, the motor was running perfect. I have 165lbs compression in the cylinders. Could I have damaged the crank? Any ideas?
