Freestyle Advent Ignition vs Solas 12V Mag Pump+Hooker
Best Freestyle Mod - Advent vs Solas 12Vein Mag Pump
  • Advent Ignition
    Votes: 0 0.0%
  • Solas 12 Vein Mag Pump
    Votes: 8 100.0%
  • Total voters
    8
So I am currently in the middle of my ski build (link below), and would like dump a little more money into it to give it that little bit more oomph. I'm trying to decide between investing in an Advent Ignition or a Solas 12Vein Mag Pump and Skat Hooker prop? My goal is purely freestyle, mostly flatwater. Any advice is greatly appreciated!
So here's what the ski will have so far:
- 96' RN Superjet, shortened 4" @ angle , rocker, pole moved forward 3-4", lowered carbon hood and pole bracket, lowered gunwales and footholds moved forward 3", floor dropped 1", and widened bond rails
- 61x Ported 83mm bore Cylinders (735cc)
- 62T Ported cases
- Speedwerx High Comp Heads
- New SBT crank
- Dual 44SBN carbs
- Vforce reeds
- Ported Factory B Pipe manifold and headpipe
- #Zero lightened flywheel
- Billet couplers
- 08'+ Superjet Impeller
Get @ocdsollutions to mod your stock cdi, and get a mag pump
Thanks for the input!
I wish I knew about OCD and their CDI options a while back. I ended up sending my MSD Enhancer to MSD to be tested and it cost me like $55 with shipping to have it come back as failed. Right now I don't have a CDI cause my MSD is shot. I have a feeling I will end up getting another MSD, a Mag Pump, and Skat Hooker and sell my 08 SJ Impeller.
CRJ
Hibernating
Toronto
Easiest way i can say it.
Putting a turbo on a car with poop tires wont make you go faster. But putting drag slicks on a car will make it hook up and go faster. The turbo is the ignition, the drag tires is the pump.
get the pump
get the pump
I can appreciate that analogy and definitely solidifies my decision for the mag pump :) Thx guys!
