Other Advent Ignition help please...
I've been having some intermittent sputtering problems on the low end, and it's getting worse and worse. I finally bought a new ignition and coils. So last night I hooked up my new advent and some coils I'm trying and I was having no luck getting the ski fired. I could get spark but the ski just would not light off. I ohm'd out my stator and it's within spec. Finally I put my stock coil in with the advent and same issue. I then put the stock ignition in with the stock coil and the ski would spark but would not fire, just the same as with the advent and my experimental coils. I once again thought stator, until my SS switch stopped working. I put in another SS switch and it fired right up and idled.
My real question, now that I know it runs fine and the stator specs out, will the advent work with my 61x stator and do I need to change the timing? Has anyone done this before?
Also in the instructions it says the brown and white wire won't be used, this is one of the wires from the stator and seems odd to me. I'm going to call them today, but that's 3 hours from now when life in Cali starts for the morning. Any input is greatly appreciated.
Ed
