Attached PDF with advance Timing plate 6º. Plate should be around 3mm thickness and grinded below the left M5 hole (manually grinded) before installation, to fit in the engine house - You can also grind a little the engine house to get space for the plate.
I installed the plate directly into a 93SX (o'ring cover), and didn't need to change the o´ring.
Just pay attention if you have spark after installed. If not, the pickup is not touching the magnet. In this case you have to reduce the 3mm thickness, or grind the old pickup fixing holes down.
