Adapting trim nozzles to steering only
Utah
Hi guys, I'm curious if anyone has the exact spacer specs to use trim nozzles for steering only without using a trim ring. I understand using a ring with or without an attached return spring is another option as the thrust will cause the steering nozzle to become properly in line.
Tuscaloosa, AL
Just measure the OD of the Reduction nozzle and the ID of the steering nozzle, then take that thickness and devide by half. then find 2 spacers that are of those sizes to use.
