ada girdled head
so I got an ADA Girdled head kit for my SXR it's the one with the adapter brackets for the girdle bolts. I cant get the 6mm studs out that are over the drive shaft coupler. I tried vise grips, double nutting it a socket style stud tool and I cant get them out. I almost broke one off with the double nuts. Ive been spraying PB Blaster on it every couple days for almost 2 months. Should I just not run the girdle set up? I'm running a wet pipe, zero lightened flywheel and rad dudes water box. Does any one have any suggestions on how to get the studs out or if I should just bail on the girdling?
