AC Racing pole --Breather tubes possible?!!
PHILLY
I'm considering getting either a Superfreak or Titan hull. I am pretty sure they both have the 2 holes for breather tubes from the pole but I will not be able to buy an RRP or other breather type pole until months down the road. Is it possible to fit the 2 breather tubes in my current AC Racing pole? I don't want to screw on a solid plate and then eventually take it off when I get a new pole with tubes and then have 4 holes drilled into my hull!
Any tips or suggestions would be appreciated, Thanks.
AC pole only has one hole for wires and cables. cant breathe thru an AC pole. put the breathers in the hood liner. your AC pole isnt going to be short enough , unless you like a long pole.
PHILLY
Thanks Buzzard! I had a feeling I couldn't put a breather tube in it. It's -2 for what it's worth, but I will definitely eventually get an X metal, RRP, or Blowsion adjustable pole as soon as my funds allow it.
Do all aftermarket hulls come set up for breather tubes with the holes pre drilled? Or is it an option and you can drill them out later? And I guess a drilling a "solid plate" would be the only solution until a get the correct pole? (If the holes are already bored open)
