A head for my SJ.
B-Roy
Makin' a Comeback!
MICHIGAN
Im thinking the next mod for my SJ will be a head.
Current specs motor wise, are just dual 38's rejetted and B Pipe Mod chamber.
What type of head should I run (girdled?)
And second, I want my ski to be as reliable as it is now, so what brand head should I go with, and what size domes?
How much performance gains can I expect from adding a head to my setup?
And is rejetting required when you add a head?
:biggthumpup:
B-Roy
Makin' a Comeback!
MICHIGAN
Is 180 going to be to much compression for free riding?
And how much of a difference will I notice from 35 cc to 37 cc domes 170 psi?
Is rejetting necessary, and will I notice quite a bit more brapp?
thanks:biggthumpup:
:biggthumpup:
So, do you have a ported cyl.? If not I would do that next. You will notice a big difference. Then buy the ADA Girdled head and get the domes for a ported cyl. You need to go down in cc's to get the same compression on a ported.
