- Fairfax, Virginia
Ski sat for a very long time, had some moisture in the motor so the crank is toast, carbs were salty so they are no good either due to broken bolts during disassembly
. Has complete electrics that are very clean, cases are good, standard bore cylinder is ok, would probably bore it just to be safe. Front storage compartment hatch is good, wear ring is trash but pump is ok otherwise
. Miscellaneous pieces parts available, let me know what you need.
