Custom/Hybrid 96 xp800 carb advice.
I have just recived a 96 seadoo xp800 that has r&d heads and a factory pipe. It was sitting up for a while so I pulled and cleaned the carbs. The motor has 170 lbs of compression in each cylinder. Can anyone help with where a good start with a high aand low starting point would be. I tried with the factory pipe specs and that didn't do the trick. I'm also at sea level not 730 above like factory pipe was with their tuning. Also any jet recommendations would be helpful.
