MikeCTM2
Auf Deutsch bitte
- Upland, California
Hello i just picked up a '96 750SXI and lovin' it! took it to QSM motorsports in Banning, CA right after i got it. had a small leak at the front of the intake grate. then they re-did the electric box and clipped the spark plug wires back. had the gas tank emptied then started fresh with Castor 927 @ 44:1 w/ 91 oct. stock ngk BR8 plugs and a k&n on each carb. evidently it has an aftermarket impeller and i see the aftermarket ride plate. took it out for the first time on tuesday and loved how it ran and the Power.
heard now how in '98 the Pro came out. i remember seein' one on CL (craigslist los angeles) and it was $500 more than twice as much as mine. and when i called someone was already getting it.
anyone else enjoyin their pre-Pro SXI? '95 - '97 any good mods?
the one thing on my mind is somehow doin' a little handle on top of the handlebar pole. so i can get up out of the water a little easier. i'm 210lbs. it's a little hard to get on the ski when you're just holding on to the handlebar grips. with my left hand i searched for anywhere to grab onto the ski where i could pull myself up and on while givin throttle with the right. nothing. the thing is smooth everywhere. Do i bust out the dremmel and cut out a grip-hole in the handlebar pole, or superglue on some little handle? Or just some getting-up advice?
Then on another thought. went down to DAna Point Harbor last Sunday. Saw FOUR SXR's talked with every owner. they say it's just a matter of flushing the ski out afterward. there was this yellow hook-up right at the base of the handlebarpole. i don't think mine has that. so can i do Salt? what if after everytime i went into freshwater the next day?
