Super Jet 96+ b pipe in 94 SN??
Utica, Mi
About to purchase a limited b pipe but says it is for a 96 and up will it still fit in a 94 sn?? Everyone i have asked said a b pipe is a b pipe? Just would like to make sure. Thanks
West MI
The exhaust manifold and waterbox coupler could be different. You can get exhaust manifolds for different motors, same for couplers, but the head pipe and exhaust pipe itself i believe are the same regardless. Mod and limited are different lengths.
West MI
Well 61x cylinder, so mani should fit i believe. JM sells couplers for the different waterboxes. Or stuff a different waterbox in there.
I just asked Factory pipe about this the other day because they have a 96 and up version and 95 and older version. They replied that the main difference is the 96 and up comes with the hose elbow to connect the chamber to the waterbox, where the older skis they use the stock hose modified. There are some other subtle hardware differences, but all of the main parts (manifold, header, chamber) are exactly the same for the B pipe kits.
West MI
All 701s in SJs are 61x cylinders, right, so the mani is the same. If you have 62t cylinder, from motor swap, mani is different. That’s all i was getting at.
