95 sn superjet
Wv
95 sn bare hull, hood, plate, pole. Hull has tubbies, some old school xft holds & decant turf. Hull is structurally good, bottom is in good shape and I recently sprayed the bottom with white base and 2k clear I had left over from something else. Hood has has top vents filled, air inlets in the back of hood with the liner cut out and has spray foam where the liner was I'm guessing hold the air intake lines in place. Ski has second water line added and still has factory bilge line. NO title, just ski hull, hood, plate, and pole. $900
